Hi all,
I've had to replace a segment of plasterboard and it had some very thick dot and dab against the brick wall.
I was planning on using some plasterboard adhesive foam but don't think it'll bring the board level with the other walls.
Would I be better battening, then screwing the boards or just going back to thick dot and dab? I presume the adhesive won't expand enough to fill the gap? It's approx 30mm.
This is an external facing wall but it's aerated breeze I'd be going onto.
