hi folks,
we have a composite front door with 3 hinges (top middle and bottom).
the type of hinges are shown in my photos, see here //www.diynot.com/network/user_album_update.php
you will see from the photos that the door is hard up against the frame (adjacent to the top hinge). This means there is a bigger gap at the lock side of the door and draught id coming in. i took the cover cap off earlier and started adjusting the allen screw to try and move door laterally/sideways to create a bit of a gap between door and frame.
The thing is that the door does not seem to move at all.
Does anyone know what type/brand of hinges these are and how to operate them? Should I be loosening the central screw on the hinge main plate before turning the allen screw, should I adjust top hinge only or top & middle incrementally?
in advance
in advance
