As the title suggests we have a couple of problems with our house (built approx 1914).
The most serious is a damp problem below the front downstairs bay window, the damp seems to be penetrating as it appears in an area on the interior wall immediately below the sill and stretches downwards from there. I have checked for any obvious places of entry on the outside wall, (the bay is constructed of stone sills and uprights with wooden frames inset) I have dug out any signs of wood rot in the frame and refilled, have checked and resealed the frame/stone joints with mastic etc. but the problem persists. The outer wall is rendered and painted (looks like pebbledash but with larger stones) Could it be that water is getting behind the render? if so would there need to be obvious cracks or visible signs of damage to the render?
Second problem relates to a stone step. The house has an open porch with a stone step at the front edge leading into a tiled porch. With time, the stone step has worn down so the level of the step slopes down from the front edge to the point where it joins the tiled area. This causes water to lodge and form a puddle. Is there any material I could use to build up the level of the step again (ideally retaining the look of original stone if possible) or does the step really need to be replaced?
Thanks in advance for any assistance offered
