My dad offered to install my catflap in my new house. I don't have a backdoor, only glass patio doors. So I opted to have one installed in the wall which gives the cat access via a tunnel.
Basically we have hit a problem in that after creating the hole we discovered there is a stud in the wall that we would need to cut through. There is one to the left and to the right as far as I can see, so my question is - can we cut through or remove a 'chunk' of the stud in order to create the tunnel and allow the catflap door to open fully. I've attached some photos.
The cat flap is being installed in a garage conversion from the back wall out in to the back garden. Would the hole need to be reinforced like a window? Would it cause major issues to cut through it?
I've included an exterior photo of where the catflap is (its been covered up behind the slab and plank of wood temporarily)
Many thanks in advance
(apologies the photos are not rotated correctly...!)
View media item 91530 View media item 91529 View media item 91528 View media item 91531 View media item 91532 View media item 91533 View media item 91535 View media item 91537 View media item 91538 View media item 91539
