- Joined
- 8 Jan 2013
- Messages
- 15
- Reaction score
- 0
- Country
Need some advice with fitting trellis.
This is my garden below, as you can see I have bungalows behind me and the garden wall isn't quite high enough to give full privacy.
My house ground floor is a foot higher than where this picture was taken from so we can currently see into eachothers properties.
I'd like to add the below, 30cm high trellis along the wall.
The wall is double brick thickness and is mine, overall height will remain below the legal height etc.
Wall is 15 years old.
I seem to have 3 options but don't know which to go for.....
Option 1. Lay a 10cm x 10cm timber batten/fence post across the top of the wall and drill that into the top of the wall.
Then attach trellis to the front side of the batten
http://www.wickes.co.uk/invt/542003
Option 2. Attach a batten horizontally to the side of the wall facing me. It would only be attached to that top layer of bricks though due to the lip that exists on the wall.
Trellis would then be attached to that batten.
Option 3. Attach verticle battens going down the wall, these will go down the wall approx 30cm, and above the wall 30cm. Trellis will then attach to the top 30cm of the battens.
Trellis 30cm high
Personally I think option 1 might be best, but not sure if it's a good idea basically attaching a wooden fence post to the top of the wall horizontally
Trellis 30cm high
