S
snadge
I have got a 35mm punch/sheer for the tap (faucet) hole itself from IKEA, but im wanting advice about cutting the 10mm hole for the punch's bolt to get through, ive bought a 10mm BOSCH drill bit as it says 10mm in the punch instructions... this is my first time cutting through a stainless steel sink so want to get as much advice as possible before i go ahead...
also,
the punch diagram shows the punch teeth coming up from bottom, well i think it might be best the other way incase any edges are bent they would be bent down out of the way of the sealer/bit that the tap sits on as this is exactly 35mm in diameter aswell so any bent up edges would stop it sitting flat/flush... has anyone got any experience with these punches?
thanks in advance
also,
thanks in advance
