Hi all, I'm new to the site and can see excellent information here
I'm a keen diyer but have got myself in a bit of a stick.
I have a door canopy, similar to the one at this link
here
The brackets each have a top and bottom fixing, they came with 8mm bolt type shield anchors, the top fixings are larger, they are 90mm length, the bottom is 60mm length. This is due to the plastic bracket has 20mm to 30mm housing for the top fixing. The instruction told me to drill with 13mm drill hole, which I have done but I didn't realise I had to drill the hole length exact and the length is more longer. The shield anchors are going round and round in the hole.
I'm now at this situation and need some advice, I'm not sure which way I should progress with, should I try nylon plugs instead?. I have four 13mm holes in the concrete wall. I'm also thinking I may need larger diameter shield anchor, maybe a 10mm or 12mm, wouldn't there be alot of margin between 8mm anchor and 13mm hole?
Thanks[/b]
here
Thanks[/b]
