Hello!
I was wondering if someone could give me a little bit of advice. I'm looking to have a couple of repairs carried out in my home, but the issue is not something I'm familiar with so I was looking for a bit of impartial advice to make sure the fix proposed is correct (i.e not a cowboy job) and the quotes are reasonable.
We have a leaking downpipe and a weathered mullion to the rear of our home (top floor tenement). Previous owners of our home have hacked into communal downpipe to attach a branch pipe and they've used a putty looking substance to fill hole - this is now leaking. As we'll need scaffolding for the pipe repair, we thought we should carry out a repair to a mullion in the same area. It's sandstone and has previously had what looks like concrete render applied over the top. This has weathered badly and the mullion is crumbling away.
So our quotes are:
1. At rear of property erect scaffold to required height to carry out works.
2. Cut out defective section of cast pipe and renew with correct branch and clip pipe.
3. Test on completion.
4. Remove defective Mullion column from between window.
5. Replace with same materials removed and test.
6. Remove all debris on completion leaving area clean and tidy.
Cost £2678.00+VAT
Quote 2
1. Erect scaffold to rear.
2. Supply and fit multi fit to downpipe, refit pipe.
3. Supply and fit mesh to mullion.
4. Render over mesh 2 coats of sand and cement.
5. Seal window to each side of mullion.
Cost £1882.00+VAT
Any advice would be appreciated, especially with regard to the mullion issue as that's out biggest cost!
So our quotes are:
Cost £2678.00+VAT
Quote 2
Cost £1882.00+VAT
