Advice identifying ch/hw system
10 Dec 2009
Middlesex
In my old place I had a pressurised combi system and I was fairly competent with basic tasks like isolating rads, removing and replacing rads, draining down systems refilling/pressurising etc
I recently moved into a new property and would like to identify what type of ch/hw system I've got so I can research the correct procedures I need to do before carrying out any work that might require me to remove any rads or any other related tasks
Im pretty sure the system isn't a pressurised combi as there is no combi boiler.
What I have got is....
A big cylinder in the upstairs cupboard with a couple of motorised valves and a pump
In the loft there is one small tank ( I think this is what you call a header tank?)
Two large tanks
I've not ben able to access them to see what each one does
View media item 95916 the pic is not great...I'll try and get another
In the kitchen down stairs some sort of boiler
View media item 95917
I can't see a pressure gauge on any of the components.
Any ideas what type of systems it is?
Open vented heating with gravity domestic water on an aging Glow Worm heat only boiler.
Standard Honeywell S plan.
All components, including the pump are knocking on in years, so budget for replacing them as and when, although they could trundle along for years more.
Cheers Dan,
The house has only had one set of previous owners from new so im guessing is the original system which makes it around 25 years old.
everything is working still but the pump is a bit noisy and the honeywell timer control unit only works on certain settings.
so yes i am planning at some point to have to replace everything.
