They had an expert advising on how to avoid damaging bursts while you're away (in response to the Northern Irelend chaos). He said that you should leave the heating on at about 10 degrees at the room thermostat and turn off the main stop cock. The heating will probably prevent bursts, but the closed stop cock will stop major damage if the worst happens. Is that good advice?
