Hello, hope this is the right place.
We are selling our house and the buyers solicitor is kicking up a fuss about an inspection chamber/access chamber not sure what it is which is the problem.
It’s a small chamber which is about a foot and a half from the house and has what seems like coax/triaxial cable 10mm diameter max coming in being spliced and returning back under the house. It doesn’t seem to be used and is in poor condition, resin splice cover is split and cable is kinked/over moved(I believe the outer sleeving is damaged but it’s underwater) at the end of the plastic cover coming out of the side but we have no clue what it is and it’s causing problems. House was built in the 60s so presumably it was put in At the same time.
And help or advice would be greatly appreciated.
Edit: I should note the kitchen is behind the wall and the electrics/phone/gas/virgin cable all enter the house at the other side of our house. Nothing inside the house to indicate this kind of cable comes in anywhere.
Images attached
Images attached
