Advice needed - new staircase
27 Sep 2011
I am replacing a staircase and have two main criteria
1. I don't plan on replacing the staircase in my lifetime so it has to last many, many years
2. I want to avoid common staircase issues such as squeaking
The staircase company want to use the following materials
Stringer Material: Pine, Whitewood (32x230mm)
Tread Material: MDF (22mm)
- Riser Material: Plywood (9mm)
Are the materials specified good enough?
That's a fairly low spec stair and may feel a little bouncy unless you fix to the wall at multiple points. Put some stairs into a mill conversion almost 2 years back on the duplexes - from memory they were 38mm softwood stringers, 28mm softwood treads, 9mm plywood risers, but we couldn't side fix to the walls which were a metal lath system. I thought they were quite a decent spec at the time
Stairs tend to last a long time - the ones in my house are 140 years old, and were hacked together by a cheap-jack Victorian builder (at least the kite winders were) so hardly something you'd have got away with in a C&G exam - but they are still OK (albeit with one or two creaks)
Stairbox? Cheap and cheerful staircases, do what they say, no reason to think you'd ever need to replace it. But as with everything you get what you pay for.
most off the stairs i have repaired for squeaks have had carpet bolstered in between the tread back and riser damaging the stair 'its not enough to cause danger but removes the support from the back off the tread causing extra load everywhere else
They are called TK Stairs
My fitter says that he doesn't like online staircase companies. Due to a bad experience where they sent out the wrong dimension stairs
Does anyone have any recommendations on a staircase company, that will preferably, come out to site, measure, then deliver the required stairs for the builder to fit?
If you let people know whereabouts you are you might get a sensible response
Hi veedee, yes I’m very interested, I’ve looked at a company called stairbox but not too sure? If you could please let me know then I can put them to my list of potentials, thanks
I used a company called 'Stair and Banister Ltd'
Ask for 'Jake' .
He came down, measured and offered some options. In the end, I chose a softwood staircase and I am delighted with it.
Good luck.. And if you do use the company, please update the thread on how you got on.
