hi guys, i am in the process of doing some work on my daughters old terraced house, there is a front porch which is of wood construction and formed along with the next door neighbours so taking it down is not an option, however tidying it up is, what i want to do is fit a second hand upvc door and frame into the outer part of the porch by fitting it into the existing timber framework and stiffening up that framework somewhat, however the one i have seen second hand the upvc frame has been cut at the corner, i believe the corner to be the oppossite side of the hinged side and at the top, so weakness wise it is probably in the right place, i know this is not ideal but my daugher has just started nursing and money is tight so dad has to do it all on the cheap, question is " is it a no go with the frame having been cut at the corner mentioned or could i or should i get the alluminium welded up any thoughts regards Dave
