Hi guys, i am in the position of purchasing some 540 TVL colour/mono CCD cameras and was looking into the wiring for these.
I have spoken to some people regarding the cable and have had mixed responses. Out of all the responses I gotm the following two were most common:
1. Get two cables, a coaxial RG59 and one for power, run them parallel to each other and wire them direct into the back of the camera i.e. removing the currect socket wires on the camera with the other end of the cable with a BNC connector for the DVR.
2. Similar to above but using a cable made for this purpose with a RG59 and power cable in on cord so to say. The disadvantage with this for me is that the cable in question is very expensive.
However with these two in mind, I bump into a friend of mine who fits CCTV systems for a living. He told me to use a CAT5 cable with baluns. The others were this practice of using CAT5 for CCTV but he highly recommended using it.
Likewise guys, what method do you guys think i should use and why. Also what do you guys think about the CAT5 option. If this method was used would I need no extra power cable going in also? Or does the CAT5 have two power cords inside also
Thanks a lot
p.s. if it helps I want to make sure that my image quality is optimal at all times, so which ever method above will enhance that, please specify for me
Thanks a lot
