Advice needed please - repainting interior woodwork
1 Sep 2009
Wiltshire
I have replaced all of my door locks and handles on some painted internal doors. I have needed to do some filling due to different sized locks and now need to repaint the doors, so the whole door looks good. I may go the whole hog and re-paint my woodwork upstairs.
The current paint is OB eggshell. It was painted a few years ago and has some chips due to having a young son, but otherwise looks nice.
I am tempted to use water based paint this time (can you get WB eggshell?) as I find it a lot easier to work with. However is it ok to paint water based on top of oil based? Also will it look as nice as it does currently, or should I re-do in oil based eggshell, as I do like the current look?
I am going to paint the doors initially, but expect that I will then want to paint the skirting boards in the landing, door frames, etc as it the door will look much brighter than the rest of the wood.
All advice appreciated.
Yes you can get WB eggshell.
As to using OB or WB read the recent thread by Joe 90 and make your own mind up.
Some of the better WB eggshells are paint & paper library, F&B and little green.
For best results its a good idea to wet abrade existing OB coating if your going to go WB its also not a bad idea to put a coat of something like coverstain or 123 (both by zinsser) to act as a bridging coat between the two products.
IMO oil based is a better finish.
