I have a flat, the hot water runs on economy 7,as there is no gas supply, there is a tank in the airing cupboard that has a kind of built in water tank above it that feeds the hot water tank. The hot water taps in the bathroom are fine, but it is very slow in the kitchen, I wanted to fit a water pump purely for the hot water from the tank. I have found a pump that is recommended purely for this purpose, it has a single input and output for the hot water from the storage tank. My only concern is, the fittings that come with the water pump are 15mm connections, but the pipe from the tank is 22mm, I don't know where it changes from 22mm to 15mm which feeds the kitchen.
I want to know, can I simply come out of the tank with 22mm, reduce to 15mm to go into the pump and then convert back to 22mm to feed the hot water?
