hi, i am going to replace 4 internal doors..the doors i will be buying are pretty cheap & the hollow type...they will need to be cut down width & heighth to fit..question is..i believe that these cheap type of doors have a batten inside going around the edges of the door..does anyone know the average thickness of that batten ? as one door in particular will need approx 3" taken off the width..so will i be able to take 1 1/2 " off one side and the same off the other side safely ?..also if it is possible..will the following info about a circular saw i will be using enable me to do the job?...........
"extra fine 185mm cutting blade with 48 teeth
maximum cutting depth 64mm at 90 degrees "
or would i need a different saw or blade ?
many many thanks in advance
