We have recently moved and the whole house will eventually need decorating so thought it was a good time to invest in some half decent stuff.
We've used both paint pads and rollers in the past, which normally give the most professional finish and is it worth buying the more expensive ones? Also is it worth buying a 'cutting in' brush as they seem pretty expensive and is a brush mate a good buy? I don't mind buying stuff if it will produce much better results but not if the difference is only minimal.
