Hi all,
Im going to be overhauling my bathroom soon(ish) with a new sink, toilet, bath, tiles the LOT! and see this as a perfect time to look into upgrading my existing hot water cylinder and maybe improving the pressure of the upstairs hot and cold.
The situation:
I live in a split level flat with one bathroom. I have a small vented hot water cylinder (which is VERY OLD about 20+ years old) which is supplied by the header tank just above it. the pressure to the bathroom taps is not too good partly due to the header tank being at head hight in the airing cupboard as I dont have a loft. the down stairs hot water also isnt up to scratch.
Our shower needs are met by a 9.5kw electric shower.
The mains pressure is alright but not amazing, havent measured the flow or pressure yet but I am able to put my thumb on the end of the tap and with a bit of force stop the flow...
The heating is all electric so no need to worry about that and only me and my g/f live in the property
The requirement:
I am wanting to replace the electric shower with a mixer shower ideally and want enough pressure to give me a more powerful shower It would also be nice if the taps in the bathroom had a bit more oomph also but the shower is priority. Hopefully this will reduce the the electricity bills a bit due to a more efficient boiler and no more electric shower
From what I can make out I have 3 options
1) Electric Combi boiler - not sure about this as why remove an electric shower just to put in an electric combi + this seems to be the most expensive option by far
2) replace the cylinder and header for a bigger header and vented cylinder and add a pump into the circuit (1.5, 2, 3 bar? im not sure what would be suitable)
3) get an unvented system - which would do away with the need for a header tank altogether however I would need to replace the current 15mm mains water pipe for 22mm and still might not have enough flow / pressure into the cylinder without an inline pump.
I need advice! Ideally I want the cheapest (to install and to run) and simplest option though I know the two arent always mutually exclusive in this situation, so the cheapest would be the best.
The situation:
The requirement:
