Right, firstly this is the only tiume i have reached this point.
I have been on this particular job since before christmas, a relatively straight forward bungalow with extension full re-wire.
Just to put you in the picture, arrived 16th Dec, shell built no stooth work, doorways, ceilings in. Great I thought. Then sat customer down and to be honest they did not really know what they wanted, so advised as much as i could. Originally 2 sparks on the job.
1 st fixed everything including burglar alarm, broke off for christmas about the 21st.
Came back 5th jan, most bthe house had been boarded and plastered!!!
Connected everything up as well as making loads of additions!!!! Finally got all circuits connected up yesterday (I know what you're thinking!!!)
Anyway got the alarm kit out to read through realising half the PIR's were missing plus a keypad.
Then began looking around the points, 4 cable ends are missing for PIR's, the door sensor lead has been stuffed by the plasterers trowel.
Re-running these cables will be a nightmare access is terrible.
To make things worse the customer had been paying a day rate but when it came to final fix they wanted a price, which I gave them.
I'm now 4 days over the time i alotted there is only the alarm to complete but I have had enough of it, i amn having to deal with other peoples screw ups, i cannot get into replace the door sensor cable!!!!
I have adjusted the bill so as not to include connecting the alarm, simply because it will be a waste of time!!!!
What I want help with is how am i going to tell the customer that I simply do not have the inclination to even attempt to install the alarm
I know this sounds totally lazy but you really have to have been on the job to realise just how bad things have been
