http://www.screwfix.com/p/drayton-trv4-white-chrome-trv-15mm-angled-l-s/34362
Im going to buy and fit some of these new trv’s and lockshileds this weekend and have a couple of questions:
I will be replacing the rad tails and compression fittings with the new ones that come in the box.
With all the joints/olives being new is it still recommended to use a joint sealing compound such as fernox lsx or boss white? (if so which is best)
Once all the valves are fitted and the system is re filled ill need to add some inhibitor.
Is there much difference in the type of inhibitor I use and how much inhibitor would you recommend for a system that comprises of 2 double rads, 1 single rad and a towel rail?
Cheers
Cheers
