There is water ingress at the lintel above my lounge window. The affected area is only damp after particularly heavy driving rain, but obviously remains stained when dry. The window is an Anglia-fitted UPVC unit fitted in 2000, so I'm pretty sure it's not a problem with the window seal. I have noticed that the pointing between the single layer of vertical bricks above the window is no longer flush and has a few cracks and holes - is this the most likely source of ingress, or should I be looking further up?
Also, is there a suitable sealer paint product that I can use to paint over the stained area, which is white textured wallpaper?
Your advice would be much appreciated.
