Would appreciate someone one checking over these images and my thought process on how I would go about replacing some copper heating pipes if needed please.
https://imgur.com/a/0WY8aTU
I'm currently, in the middle of stripping our dining room (~200 year old house, brick walls no cavity) and on the window wall the plaster had blown. Whilst removing the loose plaster I have also discovered some corroded copper pipes that feed the radiator under the window. The pipes are not protected in the wall and were plastered / cemented over in quite a shallow chase.
Do they look ok, or should I look to rip them out and replace them?
If I do replace them, I'm thinking of going with speedfit in a single run following the red lines shown in the picture, is it ok to run them this way or is it against regs? Does any one see any issues with this or have any advice on what I should use to insulate/cover the speedfit in before it is skimmed over again?
Many thanks
Many thanks
