Sorry about this but it's likely to be a long post as I think I need a new boiler and need some advice.
My current CH system was installed when my house was built in 1985. The boiler is a Glow Worm Hide Away (Balanced Flue) with an output of 40,000 - 50,000 BTU. It's a pumped system with a hot water cylinder. The pipework is microbore (8mm) and most rads have feed and returns from the same valve. (I have changed about half the rads in the house to normal valves as the valves/rads have failed over the years).
The system has generally been fine since we moved in around 1991 and I have always used a decent inhibitor in the system. This year the boiler has started to "kettle" so recently I drained the system, flushed it, and added Fernox Heavy Duty Restorer for a few weeks. Drained the system again, flushed it and added inhibitor and silencer.
It has actually improved the situation as the only time we now get the kettling is when the thermostat kicks in and the boiler shuts off. The boiler seems to kettle for about 2 or 3 minutes and then is fine until the next time it shuts off.
I have read the article about balancing the system as the furthest rads from the boiler don't get as hot as those closest and the return pipes from the rads closest to the boiler are very very hot.
Questions - If the return water is hot will this cause kettling?
Do I need a new boiler?
If I need a new boiler how good are condensing boilers?
Finally - I am reluctant to go for a combi boiler due to the fact that the ones I have experienced at friends and relatives do not actually ignite (thus providing hot water) until a fair amount of water has actually run through them. Have modern Combi boilers still got this problem?
Would anyone actually reccommend sticking with type of system I currently have?
And FINALLY if I decide to go with new condensing boiler (combi or traditional) which manufacturer makes the best and most reliable at the moment?
Thanks to all who take the time and trouble to read this and offer advice.
