I am trying to work out what size pipes to run to my new shower valve.
The existing balanced cold supply is in 15mm.
The existing hot supply is in 22mm.
The shower valve has 22mm connectors for the water supply (its a fancy thermostatic one with a divertor to provide fixed shower head and also a handset shower).
I just had a new heating system (system boiler and ariston unvented cylinder, no tanks in loft, all high pressure) fitted. Also I live in a high pressure water area.
Is it ok to just extend the existing pipes and connect them to the shower valve (with a 15>22mm adaptor in the case of the balanced cold)?
Or is it wrong to provide a shower valve with different 'volumes' (as in size of pipe) of supply in this way?
If so should I get the domestic hot down into 15mm pipe first too so it matches the bal. cold?
Cheers in advance for your help. Apologies if this is a dumb question, but I only want to do it once
