Hi all
Ive done a fair bit of plumbing in the past - re routing pipes, installing new rads, bathrooms etc but these were all on older houses where for example there was a flow to the rads, then the outlet went to the next rad etc
Ive now got a new house to plumb, and i understand that a more modern type of system has a 22mm flow and branch off to each rad, and a similar thing for the return?
So im considering using microbore, so the pipes can be hidden behind the plasterboard but is this the best way to plumb a new house and do i need to use manifolds if doing this?
Also id prefer to use copper where i can but the joists mean ill have to use some plastic 22mm for feed and return
thanks for any advice
