Hi guys.
We are getting our bedroom floor carpeted in the next month in our 30's house, and one of the things I wanted to do was to fix the squeeking and movement before the carpet gets put in. For some reason it is the only room that does not have floorboards but Chipboard. As I was going to lay network cables under the floor anyway, my plan was to pull up the chipboard, lay cables, put in noggins and then re-lay the chipboard flooring. Is this a good idea? I also have a few other questions...
Will noggins help with the movement of the floor??
Do the noggins have to be the same size as the joists, or can they be smaller. Should I screw them or will nails from a nailgun suffice?
I presume the chipboard is t&g. If it is, when relaying what is the best way to make sure that it is super solid and squeak free??
Thanks guys.
Nick
Thanks guys.
Nick
