Hi all,
I'm planning on putting up a fence where the currently stands a brick wall.
I need some advice though.
The brick wall is coming down as it is unsafe, it moves a lot and one big push would see the half of the wall come down no problem. It's roughly 50ft long, and is 5ft at it's highest point down by the house, 4ft in the middle then steps down to 3ft at the end (this is the weakest point of the wall though none of it is particularly sound).
My main issue is that my garden is level with the neighbours where the wall is 3 ft high and level with the rear alleyway, then his garden drops down about a foot, with his soil level running upwards towards the wall, but still being a half a foot lower than our level. Our garden drops down by a foot much further down, where eventually the two gardens meet level again.
The issue is, for that 15 or so feet where his garden is half a foot lower than ours how will I prevent my garden falling in to his when the wall is removed and the fence put up? Would I be best advised to leave the wall in place at the level of our garden, leaving it as a retaining wall, and fitting the fence posts in channels cut down into the wall, or fix the posts directly on to the wall (though I am unsure the wall would be strong enough to fully support it/take the drilling down in to it for the bolts.
Would I be right in thinking I would also need to measure 2m up from the top level of the garden for the max height of the fence there, and 2m up from the lower end of the garden for the max height of the fence there separately.
Just to give you a heads up, the neighbour is more than happy for the work to happen as I have already discussed it with him as the wall is beyond repair and would need a full rebuild to be safe again. Fencing seemed like the most cost effective option, but maybe not the simplest upon reflection.
Any advice would be greatly appreciated.
thanks,
thanks,
