Advice on radiator connection
30 May 2018
I’m a total novice here so apologies in advance!
My bedroom radiator was off centre and I’m wanting to move it.
It has 2 10mm polypropylene barrier pipes that run inside the wall and then attach to either side of the radiator.
In order to get the length I need to move it 16cm, I could criss-cross the two pipes attaching them to the opposite sides of the radiator than they originally where but I’m worried that this will damage the central heating system! (I don’t know if it’s a single loop or feed and return system)
Will I mess up the heating system by doing this??
Any advice appreciated
Err. I’m not sure if you'll get any help here as this is the Electrical section.
Have you considered asking in the Plumbing forum?
