Hi all,
I’m looking for some advice or previous experiences.
I have a concrete canopy above my front door that I would like to get rid of. In the last 12 months in the same neighbourhood I have seen two instances of these things shearing off and wrecking the front door. Let alone the fact that they could have killed someone.
The canopy measures approx 1800mm wide 600mm deep and about 60mm thick. I’m not sure at this stage if it also doubles up as a lintel to support the wall above.
I’m planning to build a porch around the front door anyway, and contemplated building around it. But given what has happened in the past, I would prefer to just get rid of it.
If it is the case that it is supporting the wall above, then I think the best course of action would be to just slice it off flush with the wall, with a disc cutter.
My question is, what would be the best way to go about it, and should I tackle it myself???
Cheers…
Cheers…
