Need some advice please as our hot water/heating system is 20 years old and we currently have an issue whereby radiators are coming on when the heating is OFF.
I live in a 3 storey town houses built by Bovis around 1999. We still have the original Potterton Suprima 50 which is in the kitchen on the ground floor. We have a Boilermate 3 thermal store in an airing cupboard on the top floor.
We have a British Gas Homecare contract and have the boiler service annually. We recently had the boiler PCB changed - first time in quite a few years. Others, the boiler seems OK (touch wood)!
I have had BG out and the chap reckons the port valve is not closing properly. He changed the motor siting on top - but that hasn’t solved the problem. He was reluctant to change the port valve itself as it’s in a really awkward position with difficult access and said he couldn’t guarantee no damage would occur to other pipes etc - which would then cause further problems due to lack of spares available for the Boilermate.
The recommendation was to look at changing the whole system “which would be far more efficient than what we currently have”. BG have since been round and have quoted just over £6,600 to change the boiler to a Valiant ecoTEC plus 418 Mk2 and also swap the thermal store unit for a Gledhill Unvented cylinder… add Hive Active Heating etc.
All of my neighbours have had their systems replaced with Combi boilers (cheaper option - but the British Gas surveyor reckons we couldn’t have a Combi boiler set up due to it pressurising the system which would endanger buried pipework and increase the risk of leaks.
Is he correct in saying that?
He also said that the Combi boiler wouldn’t work with our showers (he referred to them as being pumped showers - but essentially you pull the control leaver up and move it left/right to adjust the mixed temperature). He said we would need combi compatible showers - although yet again, our neighbours are operating the same original showers with their combi boilers!
Once we are out of the winter period, I will get a couple of local firms around to get advice and quote - but I would appreciate some views on options i.e. what would you do if it was you? I would ideally like to try and minimise any disruption e.g. needing to run new copper pipes that would be visible. The BG guy said this would be needed with the new system he was recommending.
Is it worth getting another view on trying to get the port valve replaced? Would I have big problems if damage to other pipes did occur when trying the get the old port valve off?
Is a new Combi system just not viable based on what the BG chap said?
Could I not just swap out the Boilermate for a new thermal store? Why change to an unvented system?
Any other suggestions welcomed…
PS… apologies for long post - but I wanted to try and give all info.
