Hi guys,
I'm trying to improve the old central heating system in my house as much as possible, this week I'm looking at the TRVs. I've got 7 rads with old Danfoss TRVs (see pictures below). A few of them don't seem to be working very well, so I was thinking about replacing the heads. I've removed the heads and it looks like the pins in the valves are moving freely, so am I right to say that replacement heads should be enough? Obviously if I can avoid replacing the whole valve, that would be good.
I wasn't entirely sure what type of TRV head I needed, but I found this page which suggests they're 17mm RA:
http://www.heatingcontrolsonline.co.uk/danfoss_table.php
That site has two suggested products, RAS-C2 which looks like the direct replacement for what I have, and the RA2910 sensor. Can anyone explain what the difference is between these two heads? I know some TRVs have remote sensors, is the RA2910 for connecting to a remote sensor? As it happens I've got two TRVs that are covered by curtains, so a remote sensor might be a good idea for them?
http://www.heatingcontrolsonline.co.uk/danfoss-randall-ra2910-sensor-p-375.html
http://www.heatingcontrolsonline.co.uk/danfoss-randall-rasc2-replacement-heads-p-324.html
I've also noticed that one of the glands has a small amount of water coming out around the pin. I found a Danfoss part guide that the replacement gland part is 013G0290, but those seem to be hard to find - I found an eBay listing for it from Germany but that's about it! Any advice on that?
Finally... if I ever have to replace a whole valve, any advice on the size of fitting I get? I'm assuming these aren't 15mm due to their age, do TRV valve sets generally come with the necessary adaptors to fit? (if you can't tell, this is me getting a bit out of my depth so I don't know if I'm asking the question correctly).
Thanks for you help!
