Hello, I will be refurbishing a 1960s house and am considering what aspects of the plumbing might need changing, there's a couple of points in particular I would appreciate advice with. Some of the pipework looks like it might be 50 years old, other bits look like they were changed more recently. The central heating system has been updated and I don't think requires any work.
The house has a downstairs bathroom and a kitchen sink, and we would like to add a new bathroom upstairs. Currently the boiler is in the attached garage and the pipe from it runs the width of the house under the floor to the bathroom, then from here it goes up to the first floor and runs under the floor boards to the back of the house. Then back across the width of the house and down to the kitchen. This all seems unnecessary when it could just run under the floor straight to the kitchen from the boiler. The total length of pipe from the boiler to the kitchen is about 30 meters whereas I think it could be done in 10 meters by going under the house. Might there be a good reason why it has been done like this and why I shouldn't reroute the pipes under the house straight to the kitchen? There is varying depth in the space below the house of 2-4 feet, but enough room to get about and the drains and some wires already run in this space.
Now for noise. All the pipework is 15mm copper and it is incredibly noisy. I do not know how the previous owner wasn't driven mad; just turn the kitchen tap on and the whole house is wooshing thanks to the elaborate route the pipes take. I haven't measured the water pressure but it does seem reasonably high and I've heard high pressure can contribute to noisy pipes. Could the age of the pipes also contribute to them being noisy, perhaps they have some internal corrosion giving friction?
So any advice on rerouting and/or noise reduction would be highly appreciated.
Thanks in advance.
Thanks in advance.
