- Joined
- 3 Aug 2016
- Messages
- 6
- Reaction score
- 0
- Country
Hey,
Currently trying to plan our flooring downstairs and just wanted a few tips really! We are looking at getting either solid wood flooring or engineered wood flooring throughout the whole of downstairs, but the Mrs wants the flooring to continue throughout the rooms without thresholds or moldings in the doorways. The area that will be done is the living room (approx 4m / 4m), dining room (approx 4m by 3m) and the entrance hallway (approx 2m / 3m ). The dining room and living room have been knocked through, so the only doorway to worry about flooring wise is the one leading from the hallway into the living room.
We have a suspended wood sub floor (wooden floorboards not the chipboard type), so I am thinking of nailing the wood flooring directly to the floorboards with a Porta nailer, but I can't find anything online whether that would cause expansion issues going through the living room doorway.
My next issue (this is the one that's baffling me!) is we are having the kitchen tiled, so essentially we would have the thickness of the plywood I need to fix to the boards, then the thickness of the adhesive, then the thickness of the tile. We want the flooring to be level throughout, so the transition from wood flooring to tiles is basically flat.
Anyone got any advice? I am thinking the tiles we were looking at are between 8 mm and 10mm thick. The kitchen is a pretty small area so any modifications to the flooring height is probably more economic to do there, I really don't want to ply the entire downstairs just because of a slightly annoying difference in floor thickness!
Thank you!
Thank you!
