have installed a cm927 honeywell room stat/programmer. I would like to use this as my programmer. At present I have it wired so that when stat calls for heat boiler comes on as well as the pump. Once the stat is satified boiler and pump go off. Is it possible to wire so that the pump continues to pump the hot water from boiler. Or are heating systems designed so that pump and boiler are on together and off together. This is a fully pumped system. But it makes sense for me that the pump continues to move water even with the boiler off. I cannot see how to wire this but I have noticed on cm927 receiver extra connections and was wondering if these could be used with pump. At present both pump and boiler together are wired to the switched live on the receiver.
