Hi
I am a 1st time tiler, and thanks to careful planning and some handy advice from this forum I have managed to tile/grout the two side walls of the corner shower tray I fitted. All that needs to be done now is the bottom row of tiles (both walls) and the corner column (again both walls).
Along the two edges of the shower tray I have siliconed in a strip of Homelux 'internal coving'. I know some would say just to go with silicone and forget the sealing strip, but after thinking about it I decided to go with it. It's the kind of strip with a slot running along the bottom for a tile to fit in, an upstand running along the wall, and a sort of curved bit which comes out the front and seals against the tray (pics available if needed!).
I'm not sure how to go about laying the tiles in here, as the slot is only really wide enough for a tile? (would be difficult to squeeze any adhesive in). Would it be best/possible to put adhesive on the back of the tile 1st then slot it in? (would it also be best to do this for the corner columns?) Will I need to put more silicone on top of the internal coving after the tiles are in?
I actually think I've managed to pull off not too bad a job (so far) so dont want to fall at the last hurdle... any help/advice will be greatly appreciated.
Thank you.
Thank you.
