Advice on toilet waste connections
21 Jan 2012
Clwyd
I'm planning to replace the downstairs toilet in the next couple of months. The waste comes out the back of the pan into a 90 degree bend, then down into the plastic pipe set in the concrete floor (house is about 20 years old if relevant). Am I right in saying that all waste pipework is push fit, including into the pan and into the pipe in the floor)? Is any form of sealant needed or are the seals on these fittings air and water tight?
The existing 90 degree fitting won't be suitable as the new pan is likely to be a bit further away from the wall than the old one, and a bit higher off the ground (I'll be fitting laminate floor). What sort of fittings will I need to look for? I've seen 90 degree bends with a flexi bit on one side like this one, which I assume is meant to go into the hole in the ground. But what about the horizontal section between pan and bend - is there such a thing as a 90 degree with flexi on both sides of the bend, or is something else needed here?
Thanks in advance.
Hard to visualise something we have never seen before. You can get long tail pan connectors, but you or someone else with eyes on site would know better, unless you can post some photos?
