Hi All,
Ive taken down a 24 inch tv and replacing with a 32 inch, so a bit heavier but the tv was fixed onto plasterboard with a deep void behind. It was fixed with
The screw holes are now loose so ive filled with loads of filler to try to fill up the hole and behind , will this be strong enough to put in Fischer wall plugs and new screws or what do you recommend to do
