Hi. I am new to this forum. Looking for advice on the easiest way to tie into an existing soil stack. The stack is in plastic with the couplings in OSMA as put in when the house was built.
I am fitting a new shower room immediately adjacent to our bathroom.through a stud work (actually condensed straw) wall. The soil stack is literally about 50 cm from the wall so distance is not a problem. The stack couplings have been exposed, and as you look at it, you have the inlet from the existing toilet in the bathroom coming in from the right, above this appears to be a separate straight couplin that the basin waste goes into. The bath waste is vented via pipe set under the floorboards into yet ab=nother couplin set below the toilet vent pipe. What appears to be a retaining plastic ring appears to have been used rather than just the normal rubber seal.
I need to fit facility for an additional toilet vent coming in on the opposite side of the stack from the existing toilet vent. I went to my local plumbers merchant and they suggeted a coupling with the 92 degree side vents one each side.
This is to replace the existing side coupling, however the replacement is not OSMA make.
Having looked at it, to reach as far as i really need to, it may well involve stripping out the existing basin and toilet in the bathroom to get to the stack, and then just replace all the existing couplings.
This is a hell of a lot of work and I was wondering if there is an easier permanent way - foir instance the clamp coupling where you cut a hole and seal an adaptor to the side. Question Is this a permanent seal, and would the bands fit adequately around the stack coupoling with the soil vent coming from the other side.
i have photos that would explain this much better if there is a way of adding them
Robin
Any help/observations would be great.
Robin
