Hi all
I'm going to be installing a new aerial point in my front room, and that's got me onto thinking about and reviewing the current set up (which we inherited when we bought the house).
The set up is:
- Roof aerial
- Feeds Wolsey WFAV 425 4-way amp/booster (in loft)
- Wolsey WPS100/1 power supplier (also in loft, connected to the amp with a small run of cable).
- White unmarked cable feeds the current aerial point in front room
- Other cables feed other points around the house but we do not use any of these....
The thoughts whirring around my head at the mo are:
- Would we be better of buying a new amp/booster seeing as we only need the one feed? Is the four way reducing quality? I remember reading once that you can buy 75ohm terminators (or something) for the unused outputs???
- I'm going to use Webro WF100 cable from the amp to the new aerial socket. Can I also use this from the socket to the TV? And can I use it for the amp/booster to the power supply?
- Should I try to replace the cable running from the aerial itself to the amp/booster with WF100? I don't have a ladder tall enough so would need to pay an installer to do this.... So only want to do that if it would be worth it....
- Any recommendations on a decent quality socket for the front room, and decent make of connectors?
Many thanks in advance for any help
Max
The set up is:
- Roof aerial
Max
