I've about 12 new holes to drill so I would think that either of these would be a good investment:
http://www.tlc-direct.co.uk/Main_Index/Ventilation_Index/Core_Drills_100mm/index.html
I'd prefer the 29.99 one mainly on cost of course but my question is to those that have experience of using one.
I also have about 8 holes that exist but the ceilings have been skimmed so the holes are now reduced to a lot less than they were (I left the fittings dangling down on their cables - not exactly safe but it seemed a good idea at the time) so they want opening up to the correct diameter.
Now this cutter, I take it that the bowl doesn't rotate and that it might be possible to hold the bowl hard against the ceiling with one hand whilst carefully (i.e. minimum pressure) cutting a new hole but of course without the pilot drill biting into anything. I reckon if I could even just get a circular score around the ragged edged hole, I might be able to finish it off with a plasterboard padsaw. I'd remove the lights and cable first of course.
Or would a stepped cone cutter be better if used very gingerly? Or is there another way anyone can suggest? Or should i just simply draw a circle and get a few plasterboard padsaws?
any advice gratefully received,
Jon.
Jon.
