Advice please Fitting a thermostatic shower
19 Nov 2014
Avon
Hello
I want to fit a thermostatically controlled shower above my bath. I have a good flow of hot and cold water to the bath and want to take a feed for the shower off the 22mm pipes which feed the bath. I was hoping to use 22mm to 15mm tee connectors as the feed for the shower. I have read somewhere where preferably you should have a separate feed for your shower,but as it's over the bath the bath and shower will not be used simultaneously.
I have a mega flow Heatrae sadia unvented hot water system with a potterton promax conventional boiler.
Any advice as always greatly appreciated
