Please could someone help with my query...
I've just had my daughters bedroom ceiling skimmed after removing the ceiling rose and replacing with a 20 amp 4 terminal junction box to continue with the loop-in system in the loft.
I'd now like to install some 50W mains downlighters, which I bought some time ago and I believe these would now require fire hoods, is this true?....
The instructions say "Under no circumstances must these fittings be covered by insulation, leaving at least 100mm space around the fitting. Space and access is not a problem as I live in a bungalow. However, the loft insulation is a concern. I think rather than going to the extent of fitting these, I would probably purchase "flameguard Downlighters" as seen here:
http://www.buy-electrical.co.uk/index.html?lang=en-uk&target=d18.html
Having not fit them before, although that shouldn't really be a problem following some posts here and i'm pretty confident with wiring. I would like some advice to how many I would need (50W mains) for a 3 metre square bedroom? What distance should they be from the walls?
Also, my lighting loop is on 1mm cable, should i continue with the same for the downlighters?
Thank you.
Thank you.
