Hello
First time poster, often been a lurker in the past.
So here goes your advice please, we have an en-suite with a Mira Discovery Thermostatic Shower http://www.plumbworld.co.uk/mira-discovery-thermostatic-1792-16357 The shower is at best a slow trickle, to get the pressure up we open all the taps and shower in the house for a few mins which clears air out of the system, cold tap then hot tap..
Although the shower is used a couple of times per day the pressure drops over time and if it isn't used for a few days.
The shower is feed from a tank in the airing cupboard the top of the is about 6inch lower then the shower head, the pipe(15mm tapped off a 22mm pipe) from the tank goes up into the loft then back down into the mixer, the cold water comes directly from the 50G water tank in the loft which can't have much more then a foot of drop.
So would fitting a shower pump improve my situation ? or would I benefit from simply fitting a surrey flange ?
also would I need to pump both hot and cold ?
And can anyone tell me what this is please? I have one in the airing cupboard and one in the loft
Wild guess its something to do with bleeding air out the system ?
