Hi there
Just had a new shower/bath fitted and replaced the area with WBP plywood as it needed to hold the shower unit.
As its a small area I've decided to do the tiling myself. We have been to Topp Tiles to see which tiles (400mm x 25mm) we want and after a bit research is it advisable that I use powder mix adhesive due to the size of the tile rather than the ready mixed stuff?
Would this stuff be ok? http://www.toppstiles.co.uk/tprod2950/section172/Bal-Single-Part-Flexible-Grey-20KG.html
Do I just mix it with water?
Also as the wall I'm tiling onto is WBP plywood, would I need to do anything to the wall/area beforehand?
Thanks in advance!
Thanks in advance!
