Hi everyone,
I'm after a bit of advice, we're having some problems keeping the temp comfortable in our home.
I have a 3 bed semi with old aluminium double glazing, the loft is insulated properly and the walls are solid so cannot be insulated. The hall way gets a draught through the wooden front door, the door does have draught excluders but the hallway is definitely the coldest part of the house.
By using the boiler C/H temp we either get the house too hot or too cold.
So after doing a bit or research I think I need a room stat in the hallway and then set TRVs in all the other rooms of the house?
Can a room stat just be added to to my existing set up or should I get rid of MT10 timer and get a programmer/room stat combo?
And which brand is the best value? any recommendations appreciated, thanks.
Jit.
Jit.
