I'd appreciate some advice from anyone with experience of fitting outdoor lights at ground level. I have had a nightmare with some lights (set on the vertical) into my patio steps. I had a set put in 8 years ago that worked perfectly well for 6 years. The screws began to get too rusted up for me to replace the bulbs, and I had some new lights installed. It's been a disaster. The first set of lights (11 in total), worked for a short time then began tripping my fuse box. I then paid for another set of lights to be installed, and had my entire patio lifted to renew the wiring. The second set of lights have been useless too. Only four out of 11 work. The manufacturer tells me it's water ingress causing the problem, so I have no redress. The lights all have an individual power cable running to each one, so a total of 11 cables running from the house under the patio. This was done during the install of the second set to ensure any problems with specific lights were easily identified.
I am now trying to find someone to help me solve this issue. I had one electrician who said he could do it and he mentioned a product that he would use that helps to make the unit water tight (the faulty lights were IP68, but let water in). He suggested using another make of light, also IP68, but suggested a 'device' to stop water ingress. The trouble is he has taken a full time job and can't now do the job, so I need to find someone who can, but I'd like to know what the 'device' is so that when I get other electricians around to see the job I can suggest they use it. I can't remember much about it, other than it was possibly a sort of brass screw type thing that sat outside the light box and stopped water getting into the unit. It has cost an absolute fortune so far, so I need to get it done as cost effectively as possible, and with a guaranteed successful outcome. I would appreciate any advice as to how to fit the lights to ensure they are as water tight as possible. Thank you in advance.
