Hi folks, first post and new to plumbing so please bear with me. i am in process of renovating an old home i bought (all i could afford ). I will be getting a plumber in to do some stuff but i want to buy materials myself so i wish to check 2 areas.
1) I am completely refitting bathroom. i need to replace radiator in there as it is in bad shape. i want to fit a towel warmer/radiator. not so concerned about the heat output as it is a small room and always warm. i have seen one on offer from scewfix direct (link below) and wonder if the TRV pack that comes with it will fit ok to pipes coming out from the floor. i have seen it somewhere else but the TRV pack was connected to pipes coming from the wall. excuse my stupidity if i have missed something but im not sure if this pack will work with pipes coming from floor. thanks.
http://www.screwfix.com/prods/65177...m;jsessionid=LY5KYJT11KMLWCSTHZOCFFY?ts=26601
2) the rest of my radiators are reasonable and apart from painting them i wish to replace the radiator valves on both ends as mine are horrible looking. i would like to put TRV on each of them (7 in total). again with each pipes are coming from the floor. am i correct in sayin that i need Angled Thermostatic Radiator Valves as opposed to straight and lockshield valves for other end. (all pipes 15mm so ok there). i am confused by the following lockshield valve as it says 15mm x 1/2 inch.........wat is the 1/2 inch part is this till ok for mine if used with a 15mm angles TRV
http://www.screwfix.com/prods/93129/Plumbing/Radiator-Valves/Terrier-Lockshield-Valve-15mm-x
appreciate your help and hope u are considerate of my lack of knowledge on plumbing.
