I have recently floored my roof space and I am in the middle of installing a 4ft florescent lighting unit.
I've the unit mounted and wired (Live - Brown, Neg - Blue and Ground - Green/Yellow) and the cable fed through the roof space to the roof space hatch where the I've installed a 2 Way Pull Cord Switch (I was given a 2 Way pull cord switch by the chap in the electrical supplies store, but I'm guessing I will just be using it as a 1 Way)
The only power feed I have access too is a wall mounted double plug socket and I'm hoping somebody can provide instructions on how I can connect the lighting unit, via the 2 Way Pull cord switch, to the wall socket.
I'm stump on how to wire/connect the wires to the 2 Way Switch so here's pictures of what I have so far and hopefully somebody can help me with this:
Lighting Unit Mounted and cable fed over to the 2 Way Pull Cord:
Cable fed through to Double Wall Socket:
(I'm assuming this will be connected as normal; Brown to Red, Blue to Black, Green/Yellow to Green/Yellow). Please correct me if I am wrong to assume this!
2 Way Pull Cord Switch with cable coming from Light Unit and Cable coming from Power Socket:
(The left cable is running from the light unit. The right cable is running from the power socket)
This is the bit I'm completely stump on and I don't want to proceed without guidance on how to wire this 2 Way switch
Can any members provide some guidance on how which wires go where?
I'm also guessing I might get some feedback that I shouldn't be wiring a light fitting into a wall socket but it's the only power source I have available in this location. If it really is a complete No No then again, please advise.
Here's hoping somebody can help me with this.
Dowser
Dowser
