I'm in the process of building a wetroom - It's a very slow process that i've been in for about 18 months now!
Anyway, I need to build out a wall slightly to hide pipework and a built-in shower valve. For this I was intending on screwing 2x1 battens to the block wall and then fixing my boards to the battens.
With regard to the boards I really don't know whether to use standard plasterboard or aquapanel. I've read a number of posts on this forum and I have the impression that aquapanel is the stuff to use. However, I don't understand how it's better than plasterboard as surely once they are both tanked they would perform the same. Can anyone shed some light as to why aquapanel is so revered?
Also, the other walls in the room have a coat of bonding plaster on them. Does anyone know of a tanking solution that can go straight on the bonding coat or should this be skimed or overboarded with pb or aquapanel prior to tiling?
Your thoughts greatly appreciated.
